Old 05-14-2003, 02:12 PM
HuFlungDung's Avatar
HuFlungDung HuFlungDung is offline
Moderator
Are you visualizing the side view of the cylinder or the end view? The end view is the one that is used to define the arc, and the cylinder axis must needs be perpendicular to it, so the selection process is nailing down the direction of the cylinder axis, which will always be perpendicular to the plane that is being described.
Any help?
