[QUOTE=Pyrotechnical;326227]I'm not sure what you are asking. The torch is a manual torch.
I am not sure.I refer from http://www.hypertherm.com/languages/...h/products.php. They shows both mechanized and manual torch.for powermax1000.
Are you asking how the plasma cutter is turned on and off? I ran an output from the breakout board to a switching transistor that activates a relay that is connected to the plasma cutter. The Hypertherm 1000 has inputs for remote start, but according to the manual they are inactive if a manual torch is connected. I'm sure there's a way around that, but in the interest of expediency I spliced into the same wiring that the manual torch switch uses
Yes,I am little puzzled with turn on and off system. What port and pin of DB-25 can turn on or off the torch of plasma? if I use mach3
Cheers,
Mongkol
