150 degrees f on the inside of the taper is the cutoff then haas says that spindle is hot. if the machine is under warranty then you should just run it till it dies run it overnight at max rpm if you come in the morning and the spindle is seized then you get a new one. then they will have to verify oil flow and make sure everything is good on the new spindle |
