Old 07-26-2007, 06:36 PM
tinman13 tinman13 is offline
tinman13 is on a distinguished road
Your preheat sounds a little short to me but then I use propane..... I like to get the heat as far through the plate as I can, within reason.
Can you set a pierce delay?
Try your cut height a little higher.
Also does the plate have much mill scale on it? That can pop off and foul a tip quickly.
The cleaner the plate the easier it is to pierce.
Good luck, Steve
