Old 07-25-2007, 05:20 PM
DSL PWR DSL PWR is offline
DSL PWR is on a distinguished road
If you have a water table try running the water so it just covers the plate. Make sure it is shallow enough that the air blows the water away from the torch during cutting. This should reduce the heat in the plate, and the warping.
Also try lowering your amperage and uping your feed rate.
On all equipment there are 2 levers...
Lever "A", and Lever F'in "B"
