070718-0638 EST USA
ninthmp:
If you have the rotation and scaling option, then you do not need to reprocess your G-code. You simply insert the correct rotation instruction at the beginning of your program.
So you could have your probe measuring function at the beginning, determuine the angle, and use G68 with the desired center of rotation and the angle passed in via the parameters A, B, and R. See the HAAS on-line manual p-126.
(edit) Far cheaper and better to adjust your vise for zero angular error. (end edit)
