This post may fit better here and get me a bit of help. Yuhodi help?
I'm at an standstill on my 4th axis. I'm using the Globe motor rotary - and have worked some of the bits and pieces (Kindly check the pics).
But I'll be darned (
would stronger wording if able--after all I am a sailor) if I can find a good gear to replace the existing one.
Note the shafting on the Globe motor is matched to the gear - but there's quite a bit of slop on my PACSCI. I've considered using
J B Weld - but seems too permanent -- any ideas?
Any sources for a gear to match better? Anybody cross this problem before?
You can see the problem - my plan is to mount a 4 jawchuck to the face of the rotary and add the unit when needed.
Thanks - and as always
Jim
