Thanks for the help. The comment on the low end torque tells me I should go with the 1725 motor. A couple of question on the Hitachi SJ200 Drive if anyone is using it. I see one pair of terminals is for remoting a reversing switch. Is that correct? Also, the panel can be removed from the unit and remoted with a cable connector. It is quite expensive but appears quite handy. Is that a special cable or can it be purchased elsewhere. Any comments on how anyone has set up the VFD would be appreciated. Thanks. |
