Old 07-12-2007, 09:44 PM
Geof Geof is online now
Originally Posted by Edster View Post
The TL-1 can be run in single or three phase. Do you guys think the output would be less if run on single phase?
If you read the specs on the Haas website it seems that on a 40amp single phase circuti the TL1 can run at full power. When it is on three phase it only needs a 25 amp circuit.
The straight answer to your question I think is no the output is not less on single phase.
