Hi everybody. I'm currently in the process of converting a SIEG Super x3 milling machine using the deluxe kit from CNC fusion (
http://www.cncfusion.com/smallmill1.html). Anyway I'm asked my electronics supplier to specify a suitable kit to complete the conversion (see below). Being a bit new to this I thought I'd get s second opinion on whether you think the specification is suitable. Any advice would be much appreciated. Thanks, Will
2 x Hybrid Nema 23 Stepper Motors for X and Y Axis.
http://www.motioncontrolproducts.com.../fl60sth86.pdf
FL60STH86-3008BF
Step Angle 1.8 Deg
Step Angle Accuracy 5% (full step, no load)
Resistance Accuracy 10%
Inductance Accuracy 20%
Temperature Rise 80OCMax.(rated current,2 phase on)
Ambient Temperature -20OC~+50OC
Insulation Resistance 100M Min. ,500VDC
Dielectric Strength 500VAC for one minute
Shaft Radial Play 0.02Max. (450 g-load) Shaft
Axial Play 0.08Max. (450 g-load) Max.
radial force 75N (20mm from the flange)
Max. axial force 15N
Voltage = 5.46
Current (phase) = 2.1 A
Inductance (phase) = 12.8 mH
Holding torque = 3 Nm
Hybrid Nema 34 Stepper Motors for Z Axis.
FL86STH80-4280A
Step Angle 1.8 Deg
radial force 220N (20mm from the flange)
Max. axial force 60N
Voltage = 3.18
Current (phase) = 4.24 A
Inductance (phase) = 3.4 mH
Holding torque = 4.51 Nm
Leads = 8
Length = 80mm
Power Supply
2 x PS 407 - 45V DC at 0A & 42V DC at 7A
3 x MSD542 Microstepping Driver (4.2A Peak)
suitable for driving 2-phase step motors (maximum current ratings of 4.2). Uses an advanced bipolar constant-current chopping technique, and a maximum input voltage of 50 VDC.
