Originally Posted by ckm Adding a thrust bearing will get rid of most of your backlash for about $20 plus a little creative engineering. McMaster has them for about $8 ea in stainless, don't forget a shaft clamp to tighten it up....
Or you can spend $500 on ball screws.
Chris. |
Isn't this something I can test for? I expect that if I do my regular backlash test (bring the spindle to zero position from both directions and measure the difference with a dial indicator), then I could measure the play/slop in the thrust bearing with a dial indicator on the end of the leadscrew....right? Because if this really is the main problem, yet it would be a no-brainer to try this first.
THanks,
-Neil.
