Nook and Rockford both sell anti-backlash double nuts. The second nut has adjustable preload for your application.
Larger balls results in added friction, and even with these, you still get .003 or so backlash. A quality adjustable preload double nut should take it down to zero.
You can reload your own balls if you want to. Probably cost you $2.00. |
