John,Im going to try the belt and pulleys the lead screw is too much $$. slow as the hot wire moves I think the belts will be ok.The set up is going to have the motor and pulley running back and forth on the open end belt fixed to the for the X. Im going to be cutting surfboard blanks 6' to 11'6" that will be shaped by hand or with a router so 1/32 or evan 1/16 will be good.Ill keep you posted.
Thanks for the input.
Mark
