If it is new that should be a warranty fix.
When the axis tries to find zero the motor drives it slowly until the limit switch is operated . Then the motor reverses and drives it slowly until the switch is released and as soon as the switch releases the controller starts looking for a zero position pulse from the encoder. What happens to cause the 168 alarm is that the pulse occurs quicker than the controller expects.
