Thread: Welding advice
Old 04-20-2004, 07:03 PM
doug6949 doug6949 is offline
doug6949 is on a distinguished road
All of the above is sound advice. To that I will add the need for practice. Close fitting joints help minimize the pull. It is not uncommon to tack the entire assembly before any welds are completed.
You will get significantly better welds with MIG (metal inert gas) if your metal is absolutely clean and free of mill scale. Flux core wire is more tolerant to surface contamination. You did not say which process you are using.
