Old 07-03-2007, 12:01 AM
mactec54 mactec54 is offline
mactec54 is on a distinguished road
Hi jubee
Its getting late here almost 12.00 midnight your late morning I gess
Yes 2048 was if the encoders were on the motor
if its on the ballscrew you could use the 1024 encoder
your 10mm pitch ballscrews will turn 2.54 times to 1"or 25.4mm
1024x4=4096/2.54=.000620" if the encoder is on the screw
if your encoder is on the motor which is 2/1 you will need to X2 the
encoder to 2048 to get the same resolution
Good luck I'm a KIWI here to help if I can
Mactec54
