Originally Posted by bearwolfe Mike,
What are the hole & slot dimensions of the pictures you posted?
TIA |
The hole is 1" ID and the slot is .75" x 2" ID.
The Torchmate 2 software has a % override feature that allows you to adjust your Program Feedrate shown in IPM. Whatever the screen displays next to the percentage sign is your Program Feedrate, and Feedrate with override applied, as shown in IPM.
The Program Feedrate is applied when you import a DXF file into the Torchmate 2 software, on the configuration screen. It shows as XY Feedrate in the top right hand corner, the default number is 70 IPM.
