Old 06-30-2007, 04:37 PM
Robin Hewitt Robin Hewitt is offline
Robin Hewitt is on a distinguished road
Originally Posted by hmc710 View Post
I did a drawing where I took a circle and Trimmed to tangential lines. The g-code did not recognize the arc. Am I going to have to re-learn how to draw using the Arc command?
G code has two commands for arcs, clockwise and counterclockwise.
It's very "go to the next point from where you are now" in it's outlook.
Arcs have an end x, y, z point and you either get a radius or an offset to the centre.
If you only get the radius there are two possible solutions so radius arcs over 180 degrees have to be broken into two but your software should be doing all this for you.
AFAIK AutoCad trims circles to arcs. OTOH I've never managed to figure out the rules for trimming rectangles, sometimes bits stick and get included in the original polyline
