Old 06-30-2007, 10:50 AM
Geof Geof is online now
It depends where the two holes are. If they are opposite each other the part will not be thrown out of balance; if they are side by side it will.
It also depends on how much material you remove and how far away the hole is from the center; a lot of material removed a short distance from the center will have less effect than a small amount removed further out.
However, having said that, I think you should do some deep thinking. If I sent a job to some shop and then a year or two later the part blew up at speed and an investigation found some of the mounting holes were oversize???? I think I might go looking for someone to crucify.
Not saying this is or is not likely but sometimes taking in in the teeth now and redoing the job is better than having the risk of taking it in the neck at a later date.
