Would this work for a CNC Stepper on a small machine or does it not have enough steps.
Thanks!
Albert
PM42L-048-TIA5 by NMB Configured with 2 coils and powered with 12 volts at 1.2 amps. The outside diameter of the NMB motor is 55 mm(2") and 25 mm(1") thick. The mounting holes are on 67 mm (1-3/4") centers. At 48 steps per revolution, and a holding torque of 1800 g.cm (63 Oz?), this stepper is a perfect match for your project. The shaft is 9/16" long by 1/8" in diameter. MOT1014.. |
