  #42
Old 06-24-2007, 08:01 PM
joecnc2006's Avatar
joecnc2006 joecnc2006 is offline
www.joescnc.com
joecnc2006 is on a distinguished road
Well the machine is getting to a point where it is harder to climb over the machine to work on it and also almost ready to move to put it into its place. I went to Harber Freight and got 4 screw jacks for 15.99 each and installed them , I need to put two more diag. bracing on the sides to make sure the machine will not flex, As it is not I can push it with my weight about 195 lbs and it does not flex, so with two more pieces i'm sure it will be good to go, And also will place some cross pieces to make a sheck for stock pieces and storage.
ID:	39626   Click image for larger version
