  #12   Ban this user!
Old 06-23-2007, 07:01 PM
serviceman's Avatar
serviceman serviceman is offline
serviceman is on a distinguished road
the newer amps hold up better than the older ones the fuses are replaceable and you can check the amps after replacing the fuse to see if you can put it back in service after replacing the fuse do a diode test on the amp between +hv and - hv and check it against a known good amp with no wires attached to either one
