Realisticaly the propane torch will not be sufficent to do this. if you still wand to do this yourself you would neen either an oxy acetelyne $$$ or an oxyMAPP torch. an oxyMAPP torch can be had from the home depot for about $40 it uses an Oxygen cylinder that looks pretty much like a propane cylinder and a MAPP gas cylinder tha can be interchanged with a propane for lighter jobs. some professional plumbers use these to speed up their work compared to plain propane. |
