Originally Posted by Cold Fusion Anyone have any advice for engraving letters in Granite? |
hello I currently own my own buisness doing just that i build everything from small keychains done with 3/4 inch gravel to commercial signs that have ranged in the 20 feet tall by 15 feet wide rocks i mostly do stone but also do glass tile and wood as for granite i will tell you the easiest is with a sandblaster i have done it with a cnc router (not recomended) i spent around 1700 to get mine fixed after doing so and the results werent the greatest as granite has alot of hard spots in it that the roter will hang up on i use a sandblast mask material that i buy from 3 m aprox 12 mil in thickness and cust it with a viny plotter and a 60 degree blade it is self adhesive but does not stick well to raw (unpolished rock) i know of a few tricks to help this but dependes on the surface of your granite weather it is smoothe or round etc email me if needed at
coltonscustoms06@msn.com i will be glad to help as for sand it also depends on the size of your rock aluminum oxide cuts the fastest but is also the most expensive if your product is small enough you can use a sandblasting cabinet wich can be picked up at a place such as harbor frieght for pretty resonable if it is too large i would suggest using black magic or black beauty it will use alot of sand so be prepared garnit also works good if you can find it most sign companys will have the sandblast mask material if not any headstone shop uses it if you wish not to try it most headstone shops will engrave it for you ( for a fee of course) you can aslo use a laser but it will only etch the surface like i said feel free to email me i will be glad to help also my website is
www.coltonscustoms.com so you can see what can be done with a sandblaster
