Old 04-16-2004, 06:58 AM
marvinstov marvinstov is offline
Gold Member
marvinstov is on a distinguished road
Yes, the end with the shoulder touches. If you have a different vice, you may have to relocate (either raise or lower) the holes for the pins so that the opposite end of the block touches the table. You will get much better clamping if the end of the block with the shoulder rests on the table. If it doesn't, you will not get much clamping force and the vice could move under heavy cutting loads.
Marv
