Originally Posted by Geof there.
If you are entering offsets you should use the OFST MSR key. I think that is the name, it is located below the F4 key. |
Part Zero Set key on our TM-1s. This will set the current absolute position into whatever G5# offset row and column that is highlighted when in Offset/ Work Coord screen. It is a time saver over having to enter in and over write a 5 place decimal value and prevents miskeys.
Scott
