  #34
Old 06-15-2007, 10:42 PM
joecnc2006's Avatar
joecnc2006 joecnc2006 is offline
www.joescnc.com
joecnc2006 is on a distinguished road
Well, I do like Bob's drawings, and is similar to what i eventually want, I did a quick bolt on Z-Axis, until i can refine the other design exactly like i want and maybe out of alumn.
This is a simple bolt on Z-Axis Slide and also the motor mount is bolted from above. It works well. and i have room for adjustment on the router mount at different bolt on heights. I found this was needed especially if you use the ATC.
Joe
ID:	39105   Click image for larger version
ID:	39106   Click image for larger version
ID:	39107   Click image for larger version
