  #11   Ban this user!
Old 06-13-2007, 02:18 PM
CNCZONERAMICO CNCZONERAMICO is offline
CNCZONERAMICO is on a distinguished road
PSI,
Not everyone is the same but if you have a very strong desire to learn anything, eventually you will fnd some way.
Late 80's early 90's I wanted to build a CNC machine using a Dremel tool, I wasn't going to cut heavy pieces or material, so I had envisioned this small desktop machine, that could be retrofitted with a Dremel high speed tool and some CNC controller of some sort. I had talked to some experts in the CNC world and pass on my idea with the Dremel tool (surely it was a logical one and probably not only my own), but I was discouraged from using one because they said it would not be strong enough. But I was not going to be machining aluminum or oak, so I reasoned that a high speed Dremel, or something similar, was ideal for cutting model building plywood, balsa and some renwood (basically bondo in block form), perhaps some light aluminum sheet.
I had already purchased a Sherline combo lathe and mill, manual, to do some hobby work, and started looking at ways to retrofit those, but I didn't have the budget for the retrofits that were being offered for such machines, at that time.
So I got a little creative within my budget, it is amazing the stuff your brain can come up with when you have the need to have something really bad and simply not the cash for such. I couldn't sleep just dreaming of this wonderful machine that will be cutting parts for me. So I got very motivated and built a "low profile" gantry style machine from some out of fashion formica night tables I had, that I almost threw them away, but luckly kept them, with the idea of some day using them, for something special and eventually I did.
The following pictures and video are the machine, the brown table is the original one before I revamped it, not much really, it used basic hardware store parts which included some industrial suprplus drawer slides some roller bearings, and nylon pieces, for the nuts and screw to motor couplers. But I made many interesting parts with such, including some aluminum test molds for another injection molding project, I had going on, at the same time. See the other pic with the small parts that range from plywood, to plastic, to thin aluminum.
That machine is still in working order, but I revamped it over the years only in the mechanical section and improved on the table look, by going with MDF shelving material and double precision drawer slides, using 10p screws and making the antibacklash nuts from delrin. The machine was, is still driven by DOS program DANCAM, DANPLOT using an older PC running windows 95, but I am sure Mach 3 ( will run it fine), it uses a driver 3 axis chopper kit , I bought in the 90's from Camtronics, steppers are Miniangle 2v,2.7A per phase about 50 oz/in and it uses a standard PC 12v 8am power supply. It is not a fast machine, but fun to play with and I've used it to teach kids how CNC machining works.
The DANPLOT DANCAM, came with a load of information that helped me understand the workings of CNC operation. You'll probably find a lot more info here, in this forum ,but that is all I had at the time. The fact I built the controllers from the "3 axis chopper kit", helped me understand how the machine talks to the controller board and what signals are sent back and forth. When you build your own you also have the power to fix it, if you are into this sort of thing. Some people don't like fixing things and it depends if you are in it for the hobby or business end, sometheing that has to be considered. But just for the sake of learning, I have since gone back to this information to try to refresh my understanding how bigger machines, that I use, might interface with Mach3 and other programs, something I am in the process of doing now. I get a little lazy sometimes and thus, I often ask questions that I already have the answers for if I do a litle homework of my own or get my hands a little dirty in the shop.
With this information you can essentially build your own machine using better more modern parts but understanding the basics is the key and if you can build a machine similar to this basic one I built years ago, step by step (you have to be patient with yourself and have a huge appetite for wanting to learn), you will have a good handle on how CNC machining works. I am sure if you look around you will find better started CNC packages that can help you in your learning endeavours.
Personally I find that there is no better training than hands on training. I have taken formal therory courses in both Umiverstities and local colleges and have gotten more from technical institutes that implement a hands on to supplement theory type teaching, but as far as CNC learning, I have learned it pretty much on my own by reading, assembling and using a bit of common sense and logic, sure keeps it fun and interesting, but that is how I learn things. I wish forums like this one would have existed in the early 90's sure would have made learning much faster.
I look around forums like this one and it blows my mind what some other people are doing, of course with better budgets the sky is the limit, but I think when you have too much of it, creativity suffers.
The hunger for knowledge seems to be contagious, in forums like this one, and it is what makes these forums work and a joy to come to. I'm always learning something new from someone that has lived longer and or has more expeienced than I have. In some levels, even people that are younger and less expereinced than I am. It is a joy to lock with people of this sort, that are willing to share their knowledge or perhaps an inspirational experience with you. Hope you find others that perhaps can share and help you get started. This post is only inspirational and I hope you success.
VIDEO
The last three pictures are things I've done for a small business I stared in 1999. Most of it is one of a kind or custom work now, word of mouth. I use more industrial machines now, for some serious work, but at first, because my work required specific machines to do specific miniature parts and I wanted to have the control of being able to produce them at any time, I had to, in some cases, make some custom machines, for these applications.
Whenever I read threads like this one , I get a bit excited and reminice the good old times and look forward to better times and think how wonderful life really is these days, of an info frenzy, and how that has and is molding us, as human beings and as a modern society. Would be nice to live forever, because, at least, I want to learn more, see more, and do more, but all of our times are limited here, and so if we can say, "I did something that I really loved doing", you can probably go with a happy face and peace of mind.
Everyone starts at some point, and we become experts with time and by learning from our mistakes.
Good Luck!
ID:	38941   Click image for larger version
ID:	38942   Click image for larger version
Name:	MIACNC 005s.jpg‎
ID:	38943   Click image for larger version
Name:	MIACNC 018s.jpg‎
Name:	MIACNC 019s.jpg‎
ID:	38950   Click image for larger version
Name:	MIACNC 020s.jpg‎
ID:	38951   Click image for larger version
Name:	MIACNC 021s.jpg‎
ID:	38952   Click image for larger version
ID:	38963   Click image for larger version
