Hey Bro,
I forgot about the 5 volts.
Sorry, i don't recognize your drives or breakout board.
If your break-out board needs 5 volts to power it, hook your 5 volt and 0 volt lines to where they are suppose to go. Your axis drives probably need either the 5 volt line or the 0 volt line hooked to it along with the step and direction lines. Your breakout board should have the 5 volt and o volt (sometimes they call the 0 volt line "ground") line output's for that. On the drives, its usually one or the other, and some drives have a switch you can change and use the 5v line or the 0v line depending on what one you want to use. Read your drive's wiring manual to see if you need the 5 volt line or the 0v line.
5 volts and 0 volts ........ 5 volts and ground........ 5 volts + & - .......all the same, but i don't like it when they call the 0v line "ground", but they do. |
