Originally Posted by Scratch It was a while ago but I think these were the settings...
Pierce height and cut height was .130
pierce dwell was 1.5 seconds
and I was using a 100 Amp tip and the standard nozzle.
I stuck a square on it and it's not quite as square as yours it looks like though...
What was your settings? |
Standard exposed 90/100 amp tip ( slightly used) Mine was a edge cut so I did not have a much pierce delay. (1 sec) 100 amps .200 Pierce height/ .190 cut height. 15 ipm. 70 lbs. air pressure while flowing. Different nozzles cut at at different speeds. I had good luck at 12 ipm. on another cut using another nozzle. I need to try a brand new eletrode and nozzle to see if it can improve. It's fine by me at this point.
