Old 06-07-2007, 09:43 PM
Chad_Clark Chad_Clark is offline
Chad_Clark is on a distinguished road
For #1
You have to select your drawing first and then copy will light up. You can do this by using "Select All" under the "Edit" menu. Then choose copy and then go to the template with the title block you want to use and select "Paste" under the "Edit" menu. You will then be able to place the drawing where ever you want on the screen with in the title block. I hope this helps.
