Thread: encoder issues
Old 04-13-2004, 09:35 PM
ynneb's Avatar
ynneb ynneb is offline
Moderator
ynneb is on a distinguished road
This is what Vlad sent me some time ago.
It works for my open end encoders.
This is how to wire up your Renco encoders.
Just leave out the Non inverse wires.
The limitation of open ended encoders is that you are limited in the distance of the cable you can run to them.
I note that Rutex also sells adapters that make your open end encoders to differential encoders. They sell them for $19.00
Pin#
Signal Name
Description
Renco - *CA18 encoder
1
+ 5V
Positive supply for encoder
RED
2
Ch – A (non inv.)
Encoder input channel A
WHITE
3
Ch – A (inv.)
Encored input channel A
YELLOW
4
Ch – B (non inv.)
Encoder input channel B
GREEN
5
Ch – B (inv.)
BLUE
6
Shield
Cable screen
SHIELD
9
0V / signal ground
Supply for encoder
BLACK
