  #12   Ban this user!
Old 06-05-2007, 09:03 PM
acondit's Avatar
acondit acondit is offline
acondit is on a distinguished road
Manual Controller
I have been working on a controller that will allow the lathe to work in manual mode (no gcode) using the cnc electronics. I designed a small circuit board that has two modes. The first mode acts as a variable speed automatic feed and the second mode uses an encoder to generate steps as the handle is turned. You can select either the X or Z axis in either mode.
Alan
ID:	38622   Click image for larger version
ID:	38623   Click image for larger version
ID:	38625   Click image for larger version
http://www.alansmachineworks.com
