Thread: Z-Axis Backlash
Old 05-11-2003, 01:55 PM
HuFlungDung's Avatar
HuFlungDung HuFlungDung is offline
Moderator
Would it be worthwhile to rig up a spring to over-counterbalance the weight of the Z components? This would pull the nut up against the "under" side of the screw thread. It might also improve Z axis performance since sometimes a little bit of binding, plus the weight could cause a stepper motor (if that is what you are using) to loose a step or two.
