You can run steppers at 20 times their rated voltage, and with such a low rating, you should run as high a voltage as you can. But, like Eric says, are they high current motors? If so, you'll probably need to use Gecko's which doesn't seem like the route you're taking.
__________________ Gerry
(Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
