Jim
Thanks for the link. Looks pretty good, however as simple as it seems to operate I can't get it to work correctly. Looking at the nc file to drill four holes, the spindle drops down and moves to all four locations but does not retract before moving to the next hole location. Could be operator error.
UPDATE:
I was looking at the g-code with NCPlot and it did not look like the spindle retracted between holes. However when I loaded it into Mach3 and did a test run it DID indeed restract between holes just as you would expect ! So, yes CamBam does do what I was looking for.
