personnally, i wouldn't use a hollow mill or any boring head on this part. you have more to worry about with a mismatch between the sections of the bosses. i would finish it with 1 tool. that way, when the diameter is set, at least the first side should always come out perfect. plus you can adjust your diameter for the half of the boss on the second side to eliminate a step. |
