Ok, i guess i will explain a little further.
The composite material is cut into strips, slide into uni-strust (as shown red in above picture) which will extend above the top of the uni-struts, It is bolted to from the bottomto the uni-struts, then i will machine the top portion skimming it with the machine to level it with the gantry, then the mdf bed will screw down to the machined composite material, when done this should be very stable with no movement.
and when i cage in the legs of the router with a lower shelf across the machine it will make a very solid frame.
Joe |
