  #12   Ban this user!
Old 06-01-2007, 10:03 AM
moldcore moldcore is offline
moldcore is on a distinguished road
Ken,
Don’t hold your breath. I’ve seen this for as long as I can remember, 11 years at least. Yes I have seen your example and I see it everyday here. I just feel its not that big a deal and easily worked around. Like I said before, I’ve checked those “gaps” and they’re not as bad as it appears. I do understand that some controllers on older machines really slow down if, using your example, you were to rotate the planer direction angle to 45 deg, from where you have it now. On newer machines the cut times are close to the same regardless of direction but the files are larger.
