My question is I would like to engrave but may Autodesk
inventor doesn’t do font for that purpose and Sprutcam
is just cam. |
SprutCAM Expert 4.0 (which Tormach sells) does have some engraving capability but I haven't tried using that yet. There used to be a tutorial for engraving on the UK SprutCAM site so you might check there to see if it is still available.
I'm pretty sure, though, that SC 4 can only use the 4th axis in indexed mode. If so you might have problems engraving all the way around a cylinder.
Try posting the question in the SprutCAM forum here on CNCZone or in the Sprut-run forum.
Mike
