Klox, I am not sure if this would be helpful, but I understand that if you bend a square bar of steel, that the bottom 1/3 of the bar is in compression (shorter) , and the top 2/3 is in tension (longer). This would give you an idea of where the neutral zone lies, which is still the original length of the bar.
__________________ First you get good, then you get fast. Then grouchiness sets in.
(Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
