You could try looking at icam or IMS post software packages. They are graphical and are flexible. You will need a licinse for each machine, but it may save you money in the long run vs. spending big money on a post. I think the going rate is$1000.00 per axis for a stand alone post.
If you are working with gibbs, send them a file with the output you want and a fiel showing the output you are getting or, just flag the output you are getting. They seem highly willing to work with me.
Addtionally, I had a toolchange issue and after sending them a copy of my file, and the output, it was a snafu on my part in the prgramming of the software which was the issue. Your situation may be the same.
Good luck |
