Old 04-10-2004, 01:14 PM
mysterious's Avatar
mysterious mysterious is offline
mysterious is on a distinguished road
If Denver cnc was partially to blame and led you in this direction, maybe they can help you out. I'm assuming they are the dealer you are referring to. I know the last time I talked to Denver they were working on a new controller rated at higher amperage, I believe they would be using geckos. I would definately talk to them first, maybe they can take in you old box and set you up with a gecko system, as a side not Denver is presently using Xylotex boards in their controllers. If Denver does not work out for you I would try camtronics. They use gecko drives and if you send them the motors you are going to use they can test your set up before shipping, Good luck.
