Old 05-14-2007, 05:54 PM
springlakecnc springlakecnc is offline
springlakecnc is on a distinguished road
Lead?
Lead, as in what you shoot out of a shotgun? You will need coolant so it don't stick to your cutter, and even that may not work. I would use as low of RPM as you can get, and watch the cutter as i think it will load up right away and break, like when you cut aluminium without coolant. Pure lead? maybe just put it into a vise and sqush it into the shape you want. Maybe if you take your wifes iron, you can iron a smooth spot. Try that when she is not at home or wear ear plugs for safty. Normally you don't machine lead.
Good Luck,
Buck Case,
Spring Lake cnc llc
