How many axis would you want dro'ed on a lathe? | | Hi,
Just found a Acu-rite 4-axis Turnmaster DRO for my lathe.
How many scales is it worth getting?
I thought about getting X Y and the toolpost slide and maybe seing if I could rig up a rotary encoder as the 4th axis to either give me a deg function on the toolpost slide (for turning tapers) or maybe fix it to the head stock and see if it would show rpm (speed).
What would you normally use a 4th axis for an a lathe?
I also toyed with the idea of fixing a scale to my tail stock so I could mesure the depth when drilling holes and tapping but it looks tricky to mount and would prevent me taking the tail stock off!
Thanks. |
