Old 05-13-2007, 07:26 PM
Oldmanandhistoy Oldmanandhistoy is offline
Oldmanandhistoy is on a distinguished road
Originally Posted by Bubba View Post
When you have the program PROPERLY set up, the axis will move to the limit switch at the Homing speed set in the ini. When the switch "trips", the axis will reverse until the switch "un-trips"
Firstly I have to say I find home switches and the way the machine homes with Turbocnc perplexing. When setting up my first machine and using the home command the Z axis would home first on its own then Y and X would home together. I actually like this method of homing as it made sure the cutter did not hit anything while homing.
On my second machine I thought I set up the software as the first machine but all axis would home at the same time but not reverse off of the switches.
I am now setting up my 3rd machine and would like to use the home switches as limit also.
Could some one please explain why my axes do not reverse from the home switches after homing.
John
