Thread: thread milling
Old 05-11-2007, 05:01 PM
fourperf fourperf is offline
fourperf is on a distinguished road
Originally Posted by ltmquik View Post
You can do all of what the other guys said or in CAMWorks create a boss feature then in the 'attributes' section choose 'THREAD'. You then need to change the settings in the 'parameters' section to the correct thread pitch, generate operations and edit the defs.
You will also need to make sure that your post is set up to post the z-axis moves. Just double check the code. The nice part about the CAMWorks threadmill is that you can add the cutter comp to the program.
I think it must be my post then. I did all you described but when it was run in the machine the machine was moving around the boss but the z was not moving at the same time. The x and y made the correct amound of revolutions around but no simultaneous Z move. I was not sure if I needed to be running 3 axis or not. I guess I simply need to have my reseller adjust my post.
Mark
