I am using Rutex R990mb motherboard. What cable is correct configuration to go from pc to motherboard 25 pin connection?
Also I understand there is revision when running Rutex tuning software, on the 15 pin connection on motherboard no resister is required. You use a jumper between 1and2. Also a jumper between 3 and 4.
What software is most compatable? Thanks for any help
mikburts |
