Old 05-09-2003, 09:41 PM
anoah anoah is offline
anoah is on a distinguished road
CastGuy2003: Thanks for the tips and the link!
Balsaman: Thanks for the info. Beleive it or not a lot has changed since I posted my first message!
I was discussing building a CNC Router with my boss and now he wants us to build a CNC Router for our metal shop for prototyping and such!
First, for my machine. I think I am going to build a PCB etcher/driller first. Would like your comments on what I am planning to use.
The table size will be 8" by 10"
I've changed my mind about controller software and I think I'm going to use KCam4. From what I've seen of the shareware dl it looks pretty impressive.
Since I don't think I need a lot of power with this small of a table and the fact that I am just etching PCB's and maybe some light wood ingraving do you think the following motors would be sufficient. BTW, I plan to use a Dremel as my cutter.
Size 17 T & L 33oz-in, 4V, .8A, 200 S/R, 6 wire, single shaft,
or should I go with Size 23 Vexta PH266-01, 83oz-in, 6V, 1.2A, 200 S/R, 6 wire, single shaft?
I plan to use the 3 Axis Version Kit controller at http://www.hobbycnc.com/driverboards.htm any one had any experiance with these?
Also, I know I will mount the stepper into my frame, connect to the threaded rod with a 2 set screw coupler, but what is the best way to attach it to the other side of the frame?
Now for Roger. He wants to build a machine with a 24" X 48" table. Does anyone know of a good set of plans in this range? We would like to stay in the $1000 range if possible. We already have a realy nice 4 HP router for it.
Thanks for all your time and responses. You guys are the best!
Albert
