Thread: bleed resistor
  #11
Old 04-27-2007, 08:52 AM
Al_The_Man's Avatar
Al_The_Man Al_The_Man is online now
Blowing a 35amp 200v (7Kw) rectifier takes some doing as they will take alot of abuse via their momentary rating.
I suspect that it may be due to the lack of isolation you have, you mention 'Ground', Ground and Common are terms that are often miss-used.
If in fact you have either deliberately or accidentally a connection of the Common to Earth Ground you will blow the rectifier, using a non-isolated source like a Variac.
I always ground my power supply commons, but I ensure a controlled situation by starting out with the proper isolation.
